scripting knx
Good morning,
I'm having a problem with the functions and I don't know how to solve it.
Here's the problem:
I currently have three logic machines taking KNX data from temperature, humidity, and CO2 sensors. I need them to calculate the average temperature, CO2, and humidity. But I only want to calculate this for the sensors located in rented properties.
I have the following variables.
Rented or non-rented status of 27 dwellings in group addresses from 2/0/176 to 2/0/202:
- Rented = 1
- Non-rented = 0
Temperature values delivered by each dwelling sensor:
'0/0/11','0/0/27','0/0/43','0/0/59','0/0/75','0/0/91','0/0/107',
'0/0/123','0/0/139','0/0/155','0/0/171','0/0/187','0/0/203',
'0/0/219','0/0/235','0/0/251',
'0/1/11','0/1/27','0/1/43','0/1/59','0/1/75','0/1/91','0/1/107',
'0/1/123','0/1/139','0/1/155','0/1/171'
Variable where the average building temperature will be stored:
2/0/164
And now I'll show you the code I wrote:
-- Direcciones de estado de las 27 viviendas (0=libre, 1=alquilada, 2=mantenimiento, 3=ocupada) local estados = {} for i = 1, 27 do     estados[i] = '2/0/' .. (175 + i)  -- 176 → 202 end -- Direcciones de temperatura individuales local direcciones_temp = {     '0/0/11','0/0/27','0/0/43','0/0/59','0/0/75','0/0/91','0/0/107',     '0/0/123','0/0/139','0/0/155','0/0/171','0/0/187','0/0/203',     '0/0/219','0/0/235','0/0/251',     '0/1/11','0/1/27','0/1/43','0/1/59','0/1/75','0/1/91','0/1/107',     '0/1/123','0/1/139','0/1/155','0/1/171' } -- Dirección donde guardar la temperatura media local destino1 = '2/0/164' -- Rango válido de temperaturas local min_temp = -20 local max_temp = 60 -- Intervalo de espera: 5 minutos (300 segundos) local INTERVALO = 300 -- ============================================================ -- BUCLE PRINCIPAL (TU MISMO CÓDIGO, REPITIÉNDOSE PARA SIEMPRE) -- ============================================================ while true do     local suma = 0     local contador = 0     -- Recorrer las 27 viviendas     for i = 1, 27 do         local estado = grp.getvalue(estados[i])         local valor = grp.getvalue(direcciones_temp[i])         -- Solo usar temperatura si la vivienda está alquilada         if estado == 1 then             if valor ~= nil and type(valor) == "number" then                 if valor >= min_temp and valor <= max_temp then                     suma = suma + valor                     contador = contador + 1                 else                     log("Temperatura fuera de rango en " .. direcciones_temp[i] .. ": " .. tostring(valor))                 end             else                 log("Valor de temperatura inválido o nulo en " .. direcciones_temp[i])             end         end     end     -- Guardar la media si hay datos válidos     if contador > 0 then         local media = suma / contador         grp.write(destino1, media)         log("Temperatura media (solo alquilados) actualizada en " .. destino1 .. ": " .. media)     else         log("No hay viviendas alquiladas con temperatura válida para calcular la media")     end     -- Esperar 5 minutos antes de repetir     os.sleep(INTERVALO) end
Lo he intentado por todos los medios posibles y no me  calcula la temperatura media y cuando lo hace satura la memoria de la logic machine.
scripting knx - by ALEJANDRO - 08.04.2026, 06:28
RE: scripting knx - by admin - 08.04.2026, 06:37
RE: scripting knx - by ALEJANDRO - 08.04.2026, 14:44
RE: scripting knx - by admin - 08.04.2026, 14:47
RE: scripting knx - by ALEJANDRO - 08.04.2026, 14:59
RE: scripting knx - by AEK - 09.04.2026, 06:50
RE: scripting knx - by ALEJANDRO - 09.04.2026, 11:22
RE: scripting knx - by admin - 09.04.2026, 12:19
RE: scripting knx - by ALEJANDRO - 10.04.2026, 08:18
RE: scripting knx - by ALEJANDRO - 13.04.2026, 13:17
RE: scripting knx - by Daniel - 13.04.2026, 13:19
RE: scripting knx - by ALEJANDRO - 13.04.2026, 13:20
RE: scripting knx - by Daniel - 13.04.2026, 13:28
RE: scripting knx - by ALEJANDRO - 13.04.2026, 13:32
RE: scripting knx - by admin - 14.04.2026, 06:33
RE: scripting knx - by ALEJANDRO - 17.04.2026, 07:51
RE: scripting knx - by admin - 17.04.2026, 08:15
RE: scripting knx - by ALEJANDRO - 21.04.2026, 13:31
RE: scripting knx - by ALEJANDRO - 04.05.2026, 06:20
RE: scripting knx - by admin - 04.05.2026, 07:40
RE: scripting knx - by ALEJANDRO - 04.05.2026, 09:07
RE: scripting knx - by admin - 04.05.2026, 13:32
