Time delay command: suggestion
You can use os.sleep together with an event script that use "Last instance only" execution mode. But this will only work if the condition is not repeated because that will restart the script.
Alternatively this solution can be adapted to your needs: https://kb.logicmachine.net/scripting/on...lay-timer/
RE: Time delay command: suggestion - by admin - 13.05.2026, 07:17
RE: Time delay command: suggestion - by admin - 13.05.2026, 10:26
