25.04.2017, 17:54
(This post was last modified: 25.04.2017, 17:54 by Erwin van der Zwart.)
I just checked, it happens only when there is a active script attached to the object, when i disable this script then it's ok.
Strange thing is that the attached script is empty so this cannot cause it so i assumed it's something in your common functions.
I see things there that are not functions and lots of functions that should not even be there if you aske me, might even be double functions (sms etc) now as you use them also from user lib.
I would suggest to clean up your common functions first, reboot and check from there..
