Amazon Polly
Here's an example on how to access Amazon Polly. Make sure you set region, accesskey, secretkey and voice variables correctly.
This has been tested on the latest RC1 firmware, but you also need to install package updates to have support for sha256 function:
Standard LM: https://dl.openrb.com/misc/luaencdec_20170426_mxs.ipk
LM power version: https://dl.openrb.com/misc/luaencdec_20170426_imx6.ipk
function getpollyurl(text)   -- CONFIG VARIABLES   local region = 'eu-west-1' -- your AWS region   local accesskey = 'xxx'   local secretkey = 'yyy'   local voice = 'Joey' -- list of voices: https://aws.amazon.com/polly/details/   -- same as JS encodeURIComponent   local function encode(str)     return (str:gsub("[^%w%-_%.%!%~%*%'%(%)]", function(c)       return string.format("%%%02X", c:byte(1,1))     end))   end   function toquerystring(items)     local res = {}     for _, item in ipairs(items) do       res[ #res + 1 ] = item[ 1 ] .. '=' .. encode(item[ 2 ])     end     return table.concat(res, '&')   end   function getkey(key, datestamp, regionname, servicename)     local kdate = encdec.hmacsha256(datestamp, 'AWS4' .. key, true)     local kregion = encdec.hmacsha256(regionname, kdate, true)     local kservice = encdec.hmacsha256(servicename, kregion, true)     return encdec.hmacsha256('aws4_request', kservice, true)   end   local encdec = require('encdec')   local method = 'GET'   local service = 'polly'   local host = service .. '.' .. region .. '.amazonaws.com'   local api = '/v1/speech'   local endpoint = 'https://' .. host .. api   local amzdate = os.date('!%Y%m%dT%H%M%SZ')   local datestamp = os.date('!%Y%m%d')   local algorithm = 'AWS4-HMAC-SHA256'   local canonicaluri = api   local canonicalheaders = 'host:' .. host   local signedheaders = 'host'   local credentialscope = datestamp .. '/' .. region .. '/' .. service .. '/' .. 'aws4_request'   local canonicalquerystring = toquerystring({     { 'OutputFormat', 'mp3' },     { 'Text', text },     { 'TextType', 'text' },     { 'VoiceId', voice },     { 'X-Amz-Algorithm', algorithm },     { 'X-Amz-Credential', accesskey .. '/' .. credentialscope },     { 'X-Amz-Date', amzdate },     { 'X-Amz-SignedHeaders', signedheaders },   })   local payloadhash = encdec.sha256('')   local canonicalrequest = table.concat({     method,     api,     canonicalquerystring,     canonicalheaders,     '',     signedheaders,     payloadhash   }, '\n')   local stringtosign = table.concat({     algorithm,     amzdate,     credentialscope,     encdec.sha256(canonicalrequest)   }, '\n')   local signingkey = getkey(secretkey, datestamp, region, service)   local signature = encdec.hmacsha256(stringtosign, signingkey)   return endpoint .. '?' .. canonicalquerystring .. '&X-Amz-Signature=' .. signature end url = getpollyurl('testing polly from logic machine') require('ssl.https') res, status = ssl.https.request(url) if res then   -- res contains the mp3 file else   alert('Polly request failed: ' .. tostring(status)) end
Amazon Polly - by bmodeco - 25.04.2017, 20:43
RE: Amazon Polly - by gjniewenhuijse - 26.04.2017, 07:27
RE: Amazon Polly - by bmodeco - 26.04.2017, 09:38
RE: Amazon Polly - by bmodeco - 26.04.2017, 18:16
RE: Amazon Polly - by admin - 27.04.2017, 05:53
RE: Amazon Polly - by bmodeco - 27.04.2017, 13:31
RE: Amazon Polly - by admin - 02.05.2017, 06:10
RE: Amazon Polly - by bmodeco - 02.05.2017, 20:14
