Wake up light
I have tested manually and it does start at last value (memory). So for example, if the last value was 30 (memory) and you use the circle/slider in the visualization, and you want to go from off to 1, it triggers the light go go from off to 30 and then down to 1. So if the room is completely dark, and you set the value to 1, it gets really bright for a quick moment before it very fast goes down to 1.
However, if the last value was 1, then you do not get this quick moment with very bright.
The ETS parameters states turn on by last received dimming value.
For the slider/circle this is not a big problem, but for my wake up light its. Because if last value before bed was 30, then I get a bright light, before it goes down to 1, and this is not very comfortable way of waking up. The only way I can see this issue solved is when turning of the night in the rom, it sets the value to 1, before turing off the light...
Mr.D
Wake up light - by Mr.D - 05.04.2017, 07:07
RE: Wake up light - by admin - 05.04.2017, 07:37
RE: Wake up light - by Mr.D - 05.04.2017, 17:11
RE: Wake up light - by Mr.D - 03.05.2017, 10:39
RE: Wake up light - by Erwin van der Zwart - 03.05.2017, 14:49
RE: Wake up light - by admin - 03.05.2017, 11:21
RE: Wake up light - by Mr.D - 03.05.2017, 15:29
RE: Wake up light - by Mr.D - 04.05.2017, 16:15
RE: Wake up light - by Erwin van der Zwart - 04.05.2017, 17:56
RE: Wake up light - by admin - 04.05.2017, 18:00
RE: Wake up light - by Mr.D - 04.05.2017, 18:11
RE: Wake up light - by Erwin van der Zwart - 04.05.2017, 18:52
RE: Wake up light - by Mr.D - 04.05.2017, 19:22
RE: Wake up light - by Erwin van der Zwart - 04.05.2017, 19:44
RE: Wake up light - by Mr.D - 06.05.2017, 11:43
RE: Wake up light - by PassivPluss - 07.05.2017, 15:57
RE: Wake up light - by Mr.D - 07.05.2017, 17:43
