Multiple event-scripts in 1 script
Try this:
function utf8tounicode(utf8str)     assert(type(utf8str) == "string")     local res, seq, val = {}, 0, nil     for i = 1, #utf8str do         local c = string.byte(utf8str, i)         if seq == 0 then             table.insert(res, val)             seq = c < 0x80 and 1 or c < 0xE0 and 2 or c < 0xF0 and 3 or                   c < 0xF8 and 4 or c < 0xFC and 5 or c < 0xFE and 6 or                   log("invalid UTF-8 character sequence")             val = bit.band(c, 2^(8-seq) - 1)         else             val = bit.bor(bit.lshift(val, 6), bit.band(c, 0x3F))         end         seq = seq - 1     end     table.insert(res, val)       resoct = {}       reshtml = {}       for i , object in ipairs(res) do         table.insert(resoct, '0' .. string.format("%o", object))         table.insert(reshtml, '&#' .. object .. ';')         end       return {res,table.concat(res),resoct,table.concat(resoct),reshtml,table.concat(reshtml)} end -- Perform action only on value true if event.getvalue() == true then      -- Load lib   require('ssl.https')   require('socket.url')        -- Set parameters   APIUser = 'YOUR_API_USERTOKEN'   APIPassw = 'YOUR_API_PASSWORD'   APIId = 'YOUR_API_ID'   Sender = '123456789'   PhoneNumber = '987654321'   Unicodetable = utf8tounicode(Eventname)   SMSText = socket.url.escape('value of ' ..  grp.find(event.dst).name .. ' is true')      -- Convert SMS text to unicode   Unicodetable = utf8tounicode(SMSText)   SMSText = Unicodetable[4]      -- Build URL   url = "https://api.clickatell.com/http/sendmsg?user="..APIUser.."&password="..APIPassw.."&api_id="..APIId.."&from=+"..Sender.."&to="..PhoneNumber.."&text="..SMSText.."&unicode=1"      -- Send Request   res, code, headers, status = ssl.https.request(url) end
Multiple event-scripts in 1 script - by Mr.D - 24.04.2017, 17:33
RE: Multiple event-scripts in 1 script - by Erwin van der Zwart - 05.05.2017, 09:44
