Wake up light
I have 2 Dali Gateway (Siemens 5WG1 141-1AB02) that controls my spotlights in the ceiling.
As far as I know, there is no booster function on this gateway. The weird part is that for one group of spotlights the lights do not "boost" up before dimming down, but for another set of spotlights it does and all this within the same Dali Gateway.... And these spotlights are all the same and uses the same type of trafo.
I have controlled the parameters within ETS for the group that does "boost" up against the ones that dont. As far as I can tell the parameters are identical.
I use data type scale (%) to control the lights... When sending 1% for some spotlights it boost up, for others it dont.
I have tried altering the data type, to 0-255 instead. If I send the value 2 it boosts up, but if I send the value 3 it dont boost up.
Both 2 and 3 produce 1% lights.
So it seems to me that for some objects the Dali Gateway interprets 1% as a value 2, but for others it is interpreted as 3...?
It is really annoying!!!
Mr.D
Wake up light - by Mr.D - 05.04.2017, 07:07
RE: Wake up light - by admin - 05.04.2017, 07:37
RE: Wake up light - by Mr.D - 05.04.2017, 17:11
RE: Wake up light - by Mr.D - 03.05.2017, 10:39
RE: Wake up light - by Erwin van der Zwart - 03.05.2017, 14:49
RE: Wake up light - by admin - 03.05.2017, 11:21
RE: Wake up light - by Mr.D - 03.05.2017, 15:29
RE: Wake up light - by Mr.D - 04.05.2017, 16:15
RE: Wake up light - by Erwin van der Zwart - 04.05.2017, 17:56
RE: Wake up light - by admin - 04.05.2017, 18:00
RE: Wake up light - by Mr.D - 04.05.2017, 18:11
RE: Wake up light - by Erwin van der Zwart - 04.05.2017, 18:52
RE: Wake up light - by Mr.D - 04.05.2017, 19:22
RE: Wake up light - by Erwin van der Zwart - 04.05.2017, 19:44
RE: Wake up light - by Mr.D - 06.05.2017, 11:43
RE: Wake up light - by PassivPluss - 07.05.2017, 15:57
RE: Wake up light - by Mr.D - 07.05.2017, 17:43
