Script with last updated event
Hi Erwin,
I cant figure out whats wrong...
1) Is your script activated?
2) Are the object names in your script correct?
3) Is the object type from object 'Timer - Settverdi - Alarm' the same for object 'Timer - Alarm' ? (can it handle the value from other object)
4) Is your time / timezone correct?
For question 1, 2 and 3:
The following code works:
Event-Based
value1 = grp.getvalue('Timer - Settverdi - Alarm') if event.getvalue() then grp.write('Timer - Alarm', value1) script.enable('Alarm - Timer') end
This code does not:
Event-Based
value1 = grp.getvalue('Timer - Settverdi - Alarm') now = os.date('*t') min = 20 max = 23 if now.hour >= min and now.hour < max then grp.write('Timer - Alarm', value1) script.enable('Alarm - Timer') end
For question 4:
I have set up the spacelynk with a NTP (time.apple.com) and the timezone is Europe/Oslo.
The update times for objects are correct as far as I can see.
I have also tried setting min = 01 and max = 23 and still nothing happens...
Mr.D
Script with last updated event - by Mr.D - 06.05.2017, 12:03
RE: Script with last updated event - by Mr.D - 06.05.2017, 22:17
RE: Script with last updated event - by Mr.D - 11.05.2017, 19:57
RE: Script with last updated event - by Jørn - 11.05.2017, 20:56
RE: Script with last updated event - by Mr.D - 13.05.2017, 20:56
RE: Script with last updated event - by Mr.D - 16.05.2017, 11:34
RE: Script with last updated event - by Mr.D - 18.05.2017, 07:40
