Delaytime not os.sleep()
Event based scripts are running in parallel when executed multiple times. To avoid this you need to kill the previous instance of the script. Try using this  and fill it up with your original script and make sure to use a unique storage name for each script you use it in:
-- check if previous script needs to be killed storage_name = 'PID_SCRIPT_1' tpid = storage.get(storage_name)   if tpid == nil then    pid = os.getpid()    storage.set(storage_name, pid) else    pid = os.getpid()      storage.set(storage_name, pid)      os.kill(tpid, signal.SIGKILL) end -- put here your script with os.sleep os.sleep(10) -- end of your scrript -- clean up storage storage.delete(storage_name)
Delaytime not os.sleep() - by d25m07y1993 - 16.05.2017, 14:14
RE: Delaytime not os.sleep() - by buuuudzik - 16.05.2017, 15:22
RE: Delaytime not os.sleep() - by d25m07y1993 - 16.05.2017, 15:50
RE: Delaytime not os.sleep() - by Erwin van der Zwart - 16.05.2017, 16:58
RE: Delaytime not os.sleep() - by buuuudzik - 16.05.2017, 16:25
RE: Delaytime not os.sleep() - by admin - 16.05.2017, 17:09
RE: Delaytime not os.sleep() - by d25m07y1993 - 17.05.2017, 03:33
