Simple Wake-on-lan
The wake-on-lan code I am using.
--[[ Librairy : Wake-on-lan Author : Matthieu Bouthors Use with mac address example : WOL("4c-cc-6a-03-55-eb") Reminder : only works if the destination is on the same subnet, not routable ]]-- function WOL(target)  local socket = require("socket")  local dest_ip="255.255.255.255"  local port=9  local udp = assert(socket.udp())  udp:setoption('broadcast', true)    clean_target = string.gsub(target,":","")  clean_target = string.gsub(clean_target,"-","")  hex_target = lmcore.hextostr(clean_target)  payload = lmcore.hextostr("FFFFFFFFFFFF")  for i=1,16 do    payload = payload .. hex_target  end    assert(udp:sendto(payload, dest_ip, port)) end
Matt
Simple Wake-on-lan - by Matt - 19.06.2017, 20:35
RE: Simple Wake-on-lan - by leonidas - 21.06.2017, 08:40
