23.06.2017, 15:39
(20.06.2017, 20:11)Erwin van der Zwart Wrote: Hi,
Use this as event based script attached to object 1/1/8:
It will generate a alert inside the alert tab, and that will be used in the alert app, can be downloaded from the appstore in FW 2.0.0.Code:if event.getvalue() == 1 then -- active alert('There is a alarm with code ' .. grp.getvalue('1/1/9') .. ' at ' .. os.date("%c", grp.getvalue('1/1/6')) end
There you will get a audio alert and a list with all available alerts.
To mail the alerts use this script as scheduled once a week: (make sure to enable 'less secure apps' in your gmail account to be able to mail and set DNS and default gateway on NIC)
Code:--Gmail (smtp) username !IMPORTANT! user = 'YOUR EMAIL ADRESS' --Gmail (smtp) password !IMPORTANT! password = 'YOUR PASSWORD' --Sender for e-mail from = '<' .. user .. '>' alias_from = 'YOUR ALIAS' --Recipient for e-mail to = '<receiver@domain.com>' alias_to = 'receiver' --Subject for e-mail subjectpart1 = 'Alerts' subjectpart2 = 'automaticly send by homeLYnk' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' -- Get all alerts from DB alerts_table = db:getall('SELECT * FROM alerts') -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "ALERT", "ADDED TO LIST") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do -- format csv row csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%x %X", alerts.alerttime)) -- add to buffer table.insert(buffer, csv) end --Create table to include mail settings local settings = { from = from, rcpt = to, user = user, password = password, server = 'smtp.gmail.com', port = 465, secure = 'sslv23', } --Create attachment inside FTP server src = 'AlertExport '.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv' dst = '/home/ftp/' .. src io.writefile(dst, buffer) --Create subject subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2 --Load required modules to send email with attachment local smtp = require("socket.smtp") local mime = require("mime") local ltn12 = require("ltn12") --Create e-mail header settings.source = smtp.message{ headers = { from = '' .. alias_from .. ' ' .. from .. '', to = '' .. alias_to .. ' ' .. to .. '', subject = subject }, --Load attachment inside body body = { preamble = "", [1] = { headers = { ["content-type"] = 'text/plain', ["content-disposition"] = 'attachment; filename="'..src..'"', ["content-description"] = '.. src ..', ["content-transfer-encoding"] = "BASE64", }, body = ltn12.source.chain( ltn12.source.file(io.open(dst, "rb")), ltn12.filter.chain( mime.encode("base64"), mime.wrap() ) ) }, epilogue = epilogue } } --Send the email r, e = smtp.send(settings) --Create alert when sending gives an error with error message if (e) then log (e) log (r) alert("Could not send email: ", e, "\n") end --Delete created file from ftp folder inside HL os.remove(dst)
Many thanks!
I'm going to implement it.
Best regards
