22.08.2017, 21:41
(19.08.2017, 14:15)admin Wrote: The version should be 20170620 or similar. It's possible that SD card became read-only. You can try replacing it with a new one, there are recovery instructions on our website in firmware page.
This was indeed the case., thank you for your support. It also explains why some modifications were lost following a power failure
This is really an issue that this kind of failure is not notified in any way to the user or administrator. Is there any function that would allow a custom script to be written in order to notify when this state occurs ? I find it happened quite fast by the way, after less than 2 years of operation, with a very light usage: low number of objets, trends...
Is there anyway to take benefit of the entire storage size of the replacement SD card ? In my case I had no 8GB card so I used a 32GB one instead... This could be useful for more precise trends during a longer time.
Finally, I think you should make the SD card accessible from the outside of the device, without having to open the case, because it can be quite tedious when almost all the wires are connected... In my case, it's a LM4, I have no idea if it has changed on newer devices...
