Receive UDP string
It works, but if I make a script like this there is 5-10 delay of sending KNX address (in if statement) after UDP string is sent by the client:
I use this code as resident with 0s interval.
Any thoughts of making this script work faster?
if not server then  require('socket')  server = socket.udp()  server:setsockname('*', 8891)  server:settimeout(1) end data = server:receive() local TerminalID = string.byte(data, 9, 12) local FingerID = string.byte(data, 33, 36) if (FingerID == 6 and TerminalID == 63) then  grp.write('4/0/10', 1) elseif (FingerID == 7 and TerminalID == 63) then  grp.write('0/5/18', 0)   end
Nevermind! I solved it by putting logic in "if data then" statement
Receive UDP string - by leonidas - 24.08.2017, 13:16
RE: Receive UDP string - by admin - 24.08.2017, 17:51
RE: Receive UDP string - by AlexLV - 24.08.2017, 22:47
RE: Receive UDP string - by leonidas - 28.08.2017, 05:25
RE: Receive UDP string - by admin - 28.08.2017, 08:54
RE: Receive UDP string - by AlexLV - 04.09.2017, 08:41
RE: Receive UDP string - by Diggerz - 15.02.2021, 01:38
RE: Receive UDP string - by admin - 15.02.2021, 07:46
RE: Receive UDP string - by Diggerz - 18.02.2021, 08:56
RE: Receive UDP string - by admin - 18.02.2021, 08:58
