LUA compilation does not work?
(05.10.2017, 21:26)Erwin van der Zwart Wrote: Hi,
You need to restart them both as the user lib is loaded into the resident script at the start of that script.
When restarting a script only makes that script require the lib again, so the new lib is loaded only into that script, the script that has not been restarted will keep using the lib content it loaded when it started.
Thanks for the explanation!
LUA compilation does not work? - by puntukas - 04.10.2017, 20:33
RE: LUA compilation does not work? - by admin - 05.10.2017, 09:27
RE: LUA compilation does not work? - by admin - 05.10.2017, 10:22
RE: LUA compilation does not work? - by puntukas - 06.10.2017, 13:27
