LM Ambient with GC-WF2IR
1. Create resident script to keep TCP connection open and handle reconnect, change IP as needed:
if not udpserver then   require('socket')   tcphost, tcpport = '192.168.2.15', 4998   function tcpclose()     if tcpclient then       tcpclient:close()       tcpclient = nil     end   end   function tcpconnect()     local res, err     -- socket already open     if tcpclient then       return tcpclient     end     -- create new sock     tcpclient = socket.tcp()     -- create ok     if tcpclient then       tcpclient:settimeout(1)       res, err = tcpclient:connect(tcphost, tcpport)       -- connect ok       if res then         return tcpclient       -- connect failed       else         alert('connection failed ' .. tostring(err))         tcpclose()       end     else       alert('failed to create socket ' .. tostring(err))     end   end   function tcpsend(cmd, retry)     local sock = tcpconnect()     if sock then       local res, err = sock:send(cmd)       if res then         sock:receive()       end       -- send failed, retry once       if not res and not retry then         tcpclose()         tcpsend(cmd, true)       end     end   end   udpserver = socket.udp()   udpserver:setsockname('127.0.0.1', 4321)   udpserver:settimeout(1) end cmd = udpserver:receive() if cmd then   tcpsend(cmd) end
2. Add to common functions:
function irsend(cmd)   require('socket').udp():sendto(cmd, '127.0.0.1', 4321) end
3. Call from event scripts:
irsend('sendir,1:1,1,37650,1,1,341,171,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,64,21,64,21,64,21,1520,342,85,21,3765\r')
LM Ambient with GC-WF2IR - by s.prathmesh - 01.07.2016, 07:42
RE: LM Ambient with GC-WF2IR - by admin - 01.07.2016, 07:54
RE: LM Ambient with GC-WF2IR - by s.prathmesh - 01.07.2016, 08:54
RE: LM Ambient with GC-WF2IR - by admin - 01.07.2016, 08:57
RE: LM Ambient with GC-WF2IR - by s.prathmesh - 01.07.2016, 09:18
RE: LM Ambient with GC-WF2IR - by AEK - 01.07.2016, 09:50
RE: LM Ambient with GC-WF2IR - by admin - 01.07.2016, 10:02
RE: LM Ambient with GC-WF2IR - by admin - 01.07.2016, 11:03
RE: LM Ambient with GC-WF2IR - by s.prathmesh - 11.07.2016, 11:50
RE: LM Ambient with GC-WF2IR - by admin - 12.07.2016, 06:03
RE: LM Ambient with GC-WF2IR - by Anh Nguyen - 22.11.2017, 09:38
RE: LM Ambient with GC-WF2IR - by admin - 22.11.2017, 13:50
RE: LM Ambient with GC-WF2IR - by Anh Nguyen - 24.11.2017, 02:04
RE: LM Ambient with GC-WF2IR - by Mr.D - 01.12.2018, 12:17
RE: LM Ambient with GC-WF2IR - by Mr.D - 17.12.2018, 11:21
RE: LM Ambient with GC-WF2IR - by admin - 17.12.2018, 12:22
RE: LM Ambient with GC-WF2IR - by Mr.D - 17.12.2018, 12:25
RE: LM Ambient with GC-WF2IR - by admin - 17.12.2018, 12:27
RE: LM Ambient with GC-WF2IR - by Mr.D - 17.12.2018, 12:32
RE: LM Ambient with GC-WF2IR - by admin - 17.12.2018, 12:42
RE: LM Ambient with GC-WF2IR - by Mr.D - 03.01.2019, 23:00
RE: LM Ambient with GC-WF2IR - by Sumit - 30.01.2020, 06:29
RE: LM Ambient with GC-WF2IR - by admin - 30.01.2020, 08:05
