Read Data from Table
Thanks for your answer, but it doesn't work, I think my script is bad I've only paste your answer after an other script from you about nest thermostat:
function request()
  local auth, url, res, stat, hdrs
  require('json')
  require('ssl.https')
  auth = '...'
  url = 'https://developer-api.nest.com/devices.json?auth=' .. auth
  res, stat, hdrs = ssl.https.request(url)
  if stat == 307 then
    res = ssl.https.request(hdrs.location)
  return json.decode(res)
res, data = pcall(request)
log(data)
alarms = data['smoke_co_alarms']['sgUHZf.....APJP7e2-z........Y']
co_alarm_ok = alarms['co_alarm_state'] == 'ok'
grp.update('1/1/1', co_alarm_ok, dt.bool)
But I think it's not the good way .. I have to create an other script ? or an other variable ?
Read Data from Table - by Alphaplasti - 28.11.2017, 08:12
RE: Read Data from Table - by admin - 28.11.2017, 09:14
RE: Read Data from Table - by Alphaplasti - 28.11.2017, 10:53
RE: Read Data from Table - by admin - 28.11.2017, 11:45
RE: Read Data from Table - by Alphaplasti - 28.11.2017, 13:58
RE: Read Data from Table - by admin - 28.11.2017, 14:28
RE: Read Data from Table - by Alphaplasti - 28.11.2017, 15:10
RE: Read Data from Table - by toujour - 14.02.2020, 07:47
RE: Read Data from Table - by AlexD - 11.10.2022, 09:02
RE: Read Data from Table - by admin - 11.10.2022, 09:24
