serial library
I need to open an rs232 port in 2 different baud rates at different times,  how do i achieve this while still receiving data from the rs232 port once the port is open again.
where is the best location to handle the opening/closing of the port and where is the best location to receive the read data?
if i put some looping code in a library
if port do
port:read(1,1)
other functions are not able to run while the loop is running what is the right method to receive data into a library, i need to keep the port open/recieved data coming in as i don't know when some string might be sent from the rs232 end point.
i have looked at the serial library doc  http://openrb.com/docs/serial.htm
and can get the code below to work and have connectivity to rs232 device
any help is much appreciated.
if not port then
  require('serial')
  port = serial.open('/dev/RS232', { baudrate = 9600, parity = 'none', duplex = 'full' })
  port:flush()
-- port ready
if port then
  char = port:read(1, 1)
  if char then
    alert(char)
serial library - by benanderson_475 - 03.01.2018, 21:12
RE: serial library - by admin - 04.01.2018, 08:02
RE: serial library - by benanderson_475 - 04.01.2018, 19:59
RE: serial library - by admin - 05.01.2018, 08:24
RE: serial library - by benanderson_475 - 08.01.2018, 10:30
RE: serial library - by admin - 09.01.2018, 13:50
