Factory reset LM5
(08.01.2018, 18:44)KingCanute Wrote: Is there a way to factory reset an LM5 without logging in? I'm sure what has happened to it, I can't reach on web from the IP adress I used for it. The adress is static, but it won't respond the trying to login to it.
Is it possible that the internal SD card is faulty?
Hi, if you have phisical access to LM you can use reset button.
hold it for 10 seconds (until red Led start blinking) - it will reset IP settings to 192.168.0.10 (project settings will be kept)
if you still have no access. press button once again for 10 seconds - it will do full factory reset
Factory reset LM5 - by KingCanute - 08.01.2018, 18:44
RE: Factory reset LM5 - by AEK - 09.01.2018, 06:55
Factory reset LM5 - by KingCanute - 09.01.2018, 07:00
RE: Factory reset LM5 - by AEK - 09.01.2018, 07:04
Factory reset LM5 - by KingCanute - 09.01.2018, 09:47
RE: Factory reset LM5 - by admin - 09.01.2018, 10:39
Factory reset LM5 - by KingCanute - 09.01.2018, 12:24
