17.01.2018, 07:10
Quote:I use export/import feature. Since exported layout is just .json file, you can modify it using any favorite programming language.
Hi, thank you for your answer. I've previously changed the number of visual objects etc. by editing the db files that included in the backup. This time, I would like to do it in Lua since it requires less setup for the person that will run the script.
Is there any way to edit the database in Lua?
