Send notifications via pushover
(01.02.2018, 15:37)bmodeco Wrote:
(01.02.2018, 13:09)admin Wrote: Try this, I've tested it with nginx and apache so other servers might reject this request. Fill params table with your post arguments, filedata variable should contain binary data of your jpeg image, set request url as needed.
require('ssl.https') boundary = os.date('%d%m%Y%H%M%S') params = {  {    name = 'token',    value = '12345',  },  {    name = 'user',    value = 'testuser',  },  {    name = 'attachment',    filename = 'snapshot.jpg',    ctype = 'image/jpeg',    value = filedata,  } } body = { '--' .. boundary } for _, param in ipairs(params) do  line = string.format('Content-Disposition: form-data; name=%q', param.name)  if param.filename then    line = string.format('%s; filename=%q', line, param.filename)  end  body[ #body + 1 ] = line  if param.ctype then    body[ #body + 1 ] = string.format('Content-Type: %s', param.ctype)  end  body[ #body + 1 ] = ''  body[ #body + 1 ] = param.value  body[ #body + 1 ] = '--' .. boundary end -- last boundary body[ #body ] = body[ #body ] .. '--' -- empty line at the end body[ #body + 1 ] = '' bodydata = table.concat(body, '\r\n') resp = {} log(  ssl.https.request({    url = 'https://...',    sink = ltn12.sink.table(resp),    method = 'POST',    source = ltn12.source.string(bodydata),    headers = {      ['content-length'] = #bodydata,      ['content-type'] = 'multipart/form-data; boundary=' .. boundary    }  }) ) log(table.concat(resp))
Thanks admin for the fast response! Will try it out.
Thanks I will try it.
local data_str = 'token=token&user=user&device=gsm&message=test&attachment='??????'&title=LogicMachine&sound=bike&priority=0'
local res, code, headers, status = ssl.https.request(pushover_url, data_str)
RE: Send notifications via pushover - by Keitz - 01.02.2018, 17:03
