30.12.2015, 07:20
First, you have to make sure that your camera can stream in MJPEG format over HTTP. This is the only format that all browsers support without additional plugins. Unfortunately some newer cameras don't have MJPEG support.
To get the correct URL you have to open camera web interface, right click on stream image and select "Copy image location" or similar. Then you can try opening this URL in your browser. If it works then it's probably a correct URL and it can be used in LM visualization.
You can also try searching for your camera model, here are some links:
https://github.com/sightmachine/SimpleCV...tream-URLs
http://www.bluecherrydvr.com/2012/01/23/...k-cameras/
