Trends API
(07.12.2016, 20:15)Pawel Wrote: Thanks Erwin, those scripts save me a lot of time. I made a small change and all objects with specific tag will have own trend:
-- Batch adding trends - Created by Erwin van der Zwart - Schneider Electric Netherlands ----------- -- For spaceLYnk FW 1.2.1 or higher and homeLYnk FW 1.5.1 or higher -------------------------------- -- Refresh browser after creation to show the trends ----------------------------------------------- ----------------------------------------- Start Parameters ----------------------------------------- -- Create trend to object with this tag  tag_name = "make_trend" -- Set username and password for access to HL username = 'admin' password = 'admin' -- Select trend type to create (or multiple types on same object) create_trendtype_counter = true create_trendtype_counter_with_negative_delta = true create_trendtype_absolute_value = true -- Set trend precicion (!Important! Can only be these values: 0 to 8) trendprecision = 0 -- Set trend resolution (!Important! Can only be these values: 5 / 10 / 15 / 20 / 30 / 60 minutes)) trendresolution = 15 -- Set trend count resolution (!Important! Can only be these values: '30' = 30 days, '180' = 180 days, '365' = 1 year, '730' = 2 years, '1825' = 5 years trendcountresolution = 365 -- Set trend count days (!Important! Can only be these values: '1' = 1 year / '2' = 2 years / '5' = 5 years / '10' = 10 years) trendcountdaily = 10 -- Set show always 0 base line  trendshowzero = 0 -- 0 = disabled 1 = enabled ------------------------------------------ End Parameters ------------------------------------------ ------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE ------------------------------- -- Load modules require('json') require('socket.url') require('socket.http') -- Set HL ip address as localhost ip = '127.0.0.1' -- Create url for trend creation url = 'http://' .. username .. ':' .. password .. '@' .. ip .. '/scada-main/trends/save' -- Function to send request to create trend function url_send(trend_object, trend_name, trend_type, trend_resolution, trend_precision, trend_count_resolution, trend_count_daily, trend_show_zero, trend_id)   local trend = {       object = trend_object,       name = trend_name,       type = trend_type,       resolution = trend_resolution,       precision = trend_precision,     count_resolution = trend_count_resolution * 12 * 24, -- nr of days * nr of points in a hour at min resolution (60/5 = 12) * hours per day     count_daily = trend_count_daily * 365, -- nr of days * 365 days a year       show_zero = trend_show_zero,       id = trend_id,     }   data = json.encode(trend)     form_data = 'data=' .. socket.url.escape(data)     socket.http.TIMEOUT = 15        local res, code, response_header = socket.http.request(url, form_data)   return res, code, response_header end -- Set counters for creation log number_of_trends = 0 number_failed = 0 objectwithtag = grp.tag(tag_name) -- Loop for each group adress with specific tag  for key, value in pairs(objectwithtag) do      -- Get current group address from loop    current_GA = knxlib.decodega(value.id)      -- Get current object info   objectinfo = grp.find(current_GA)        -- Check if object excists   if objectinfo ~= nil then            -- Set parameters for request     trendobject = objectinfo.id     trendname = objectinfo.name     trendid = ''          -- Check if trend type 'Counter' should be created     if create_trendtype_counter == true then              -- Call function to send create request       result, code, response_header = url_send(trendobject, trendname, 'C', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)              -- Calculate results for creation results log         if result == '{"success":true}' then           number_of_trends = number_of_trends + 1         else           number_failed = number_failed + 1         end            end          -- Check if trend type 'Counter with negative delta' should be created     if create_trendtype_counter_with_negative_delta == true then                    -- Call function to send create request       result, code, response_header = url_send(trendobject, trendname, 'D', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)                  -- Calculate results for creation results log         if result == '{"success":true}' then           number_of_trends = number_of_trends + 1         else           number_failed = number_failed + 1         end            end          -- Check if trend type 'Absolute value' should be created     if create_trendtype_absolute_value == true then                    -- Call function to send create request       result, code, response_header = url_send(trendobject, trendname, 'G', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)                  -- Calculate results for creation results log         if result == '{"success":true}' then           number_of_trends = number_of_trends + 1         else           number_failed = number_failed + 1         end            end        end    end      if number_failed == 0 then     log ("Created " .. number_of_trends .. " trends succesfully") else     log ("Created " .. number_of_trends .. " trends succesfully and creation of " .. number_failed .. " trends failed") end -- Disable script when done automaticly script.disable(_SCRIPTNAME)
Hi Pawel,
in this case don't you create .csv file?
Trends API - by buuuudzik - 28.05.2016, 16:52
RE: Trends API - by Habib - 28.05.2016, 17:13
RE: Trends API - by Erwin van der Zwart - 28.05.2016, 22:01
RE: Trends API - by admin - 29.05.2016, 06:12
RE: Trends API - by buuuudzik - 29.05.2016, 11:22
RE: Trends API - by Erwin van der Zwart - 02.09.2016, 18:46
RE: Trends API - by admin - 05.09.2016, 06:01
RE: Trends API - by Erwin van der Zwart - 05.09.2016, 09:29
RE: Trends API - by Pawel - 07.12.2016, 20:15
RE: Trends API - by Domoticatorino - 19.02.2018, 15:39
RE: Trends API - by Erwin van der Zwart - 19.02.2018, 16:32
RE: Trends API - by Domizy - 18.12.2024, 14:24
RE: Trends API - by Domoticatorino - 13.02.2018, 16:52
RE: Trends API - by Daniel - 13.02.2018, 18:49
RE: Trends API - by Domoticatorino - 19.02.2018, 16:33
RE: Trends API - by PassivPluss - 17.09.2019, 21:10
RE: Trends API - by admin - 24.09.2019, 06:53
RE: Trends API - by Trond Hoyem - 17.06.2022, 12:57
RE: Trends API - by admin - 17.06.2022, 13:20
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:23
RE: Trends API - by admin - 17.06.2022, 13:23
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:27
RE: Trends API - by admin - 17.06.2022, 13:30
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:33
RE: Trends API - by admin - 17.06.2022, 13:34
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:36
RE: Trends API - by admin - 17.06.2022, 14:15
RE: Trends API - by Trond Hoyem - 17.06.2022, 14:26
RE: Trends API - by admin - 17.06.2022, 14:32
RE: Trends API - by Daniel - 18.12.2024, 14:51
RE: Trends API - by Domizy - 18.12.2024, 15:06
RE: Trends API - by Daniel - 18.12.2024, 15:29
RE: Trends API - by Domizy - 18.12.2024, 15:39
RE: Trends API - by Erwin van der Zwart - 19.12.2024, 14:57
RE: Trends API - by Domizy - 19.12.2024, 17:30
RE: Trends API - by avolle - 03.12.2025, 18:22
RE: Trends API - by admin - 04.12.2025, 08:07
