ssh to shut down a remote pc
First you need to generate your private key and extract public key from that, create a script and run it once:
key = '/lib/genohm-scada/mnt/storage/id_rsa' os.execute('dropbearkey -t rsa -f ' .. key) keyinfo = io.readproc('dropbearkey -y -f ' .. key) log(keyinfo)
In logs you will see a line like "ssh-rsa AAAAB3Nz...", you have to copy it to authorized_keys (or authorized_keys2) file on your HTPC.
Then you can run any command via SSH which does not require user input:
key = '/lib/genohm-scada/mnt/storage/id_rsa' user = 'root' ip = '192.168.1.100' port = 22 cmd = 'ls' run = string.format('ssh -y -i %s %s@%s/%d %q', key, user, ip, port, cmd) result = io.readproc(run) log(result)
RE: ssh to shut down a remote pc - by admin - 05.01.2016, 07:37
RE: ssh to shut down a remote pc - by admin - 06.01.2016, 07:52
RE: ssh to shut down a remote pc - by baggins - 29.10.2016, 10:40
RE: ssh to shut down a remote pc - by baggins - 30.10.2016, 20:31
RE: ssh to shut down a remote pc - by Igor - 25.06.2020, 09:41
RE: ssh to shut down a remote pc - by admin - 25.06.2020, 11:07
