Check SD card errors
Here you have script for checking SD card current errors:
function checkSDCardErrors()     f = assert (io.popen('dmesg | grep mmcblk'))     errorsCounter = 0     for line in f:lines() do      isThereSDError = line:match("mmcblk*..*: (.*error*..*)")    if isThereSDError then errorsCounter = errorsCounter + 1 end     end     f:close()  return errorsCounter end log(checkSDCardErrors())
It can be helpful in monitoring SD card and knowing about start of problems and that it must replacedWink
Check SD card errors - by buuuudzik - 23.02.2018, 21:21
RE: Check SD card errors - by baggins - 21.09.2018, 21:30
RE: Check SD card errors - by buuuudzik - 21.09.2018, 21:51
RE: Check SD card errors - by Daniel - 24.09.2018, 07:34
RE: Check SD card errors - by baggins - 24.09.2018, 11:28
RE: Check SD card errors - by buuuudzik - 24.09.2018, 07:50
RE: Check SD card errors - by Daniel - 24.09.2018, 08:15
RE: Check SD card errors - by buuuudzik - 24.09.2018, 08:29
RE: Check SD card errors - by Daniel - 24.09.2018, 08:32
RE: Check SD card errors - by buuuudzik - 24.09.2018, 11:49
RE: Check SD card errors - by FatMax - 28.10.2018, 15:07
RE: Check SD card errors - by buuuudzik - 28.10.2018, 15:22
RE: Check SD card errors - by FatMax - 28.10.2018, 15:24
RE: Check SD card errors - by admin - 29.10.2018, 07:01
RE: Check SD card errors - by buuuudzik - 29.10.2018, 07:14
