Data from http request - to JSON - to KNX
Here is the solution, thank to you that know who you are. Wink
And thanks for all the help also! Smile
sock = require('socket').tcp() sock:settimeout(5) res, err = sock:connect('10.0.0.112', 80) if res then  sock:send('GET /output.json HTTP/1.1\r\n\r\n')  res = sock:receive('*a')  log(res)  if res then    p, e = res:find('\r\n\r\n', 1, true)    if e then      data = res:sub(e + 1)      data = require('json').pdecode(data)      log(data)    end  end end if data then  CurrentSummationDelivered = data['0015BC001B024257'].CurrentSummationDelivered  InstantaneousDemand = data['0015BC001B024257'].InstantaneousDemand  grp.write('4/0/20', tonumber(CurrentSummationDelivered))  grp.write('4/0/21', tonumber(InstantaneousDemand)) end
RE: Data from http request - to JSON - to KNX - by Rune - 21.03.2018, 20:11
