Shutdown remote PC
Way to pass a http-command to a PC.  Used here to shutdown a PC
Security is obviously not a concern in this solution.
Please share your improvements.  Autodetect for Linux / Windows would be nice.
local http = require("socket.http") local url = require("socket.url") local socket = require("socket") -- -- This function does remote function invocation like: -- http://username:password@127.0.0.1:8080/action?name=alarm -- It is assumed, that username and password are present in the url; -- another assumption, that on the windows machine there will be -- installed software like "shutter", see http://www.den4b.com/?x=products -- -- if wait_delay is defined positive, then after wait_delay seconds it -- will do "TCP knock" to check if the remote host is alive. Is if is -- still alive, then notification email will be sent. -- function shutdown_regular(command_url, wait_delay)    local admin_email = 'mrx@openmailbox.org'    -- tcp knock help function    function tcp_knock(ip, port)       local tcp = assert(socket.tcp())       tcp:settimeout(10)       local success = tcp:connect(ip, port)       print("tcp knock to " .. ip .. " is " .. (success and "success" or "fail"))       return success    end    -- prepare data    local parsed_url = url.parse(command_url)    local host = parsed_url.host    local port = parsed_url.port or 80    -- invoke command url    http.TIMEOUT = 10    print(command_url)    local body, code = http.request{ url = command_url }    assert(body, code)    print("status = " .. code)    -- success invocation check    if (code ~= 200) then       local subject = "Remote command invocation failed on " .. host       local body = "Please, pay attention the host " .. host .. " returned status code = " .. code .. "\n"       body = body .. "the following command url: " .. command_url .. "\n"       mail(admin_email, subject, body)       return    end        wait_delay = tonumber(wait_delay)    if ( wait_delay and (wait_delay > 0) ) then       os.sleep(wait_delay)       local success = tcp_knock(host, port)       if ( not succeess ) then          local subject = "Remote command invocation failed on " .. host          local body = "Please, pay attention the host " .. host .. " is still alive after invocation \n"          body = body .. "the follwong command url: " .. command_url .. "\n"          mail(admin_email, subject, body)       end    end end -- uncomment the following lines to perform command-line test from linux --[[ function mail(to, subject, body)    print("mail function simulation. to = " .. to .. ", subject = " .. subject .. "\n" .. body) end function os.sleep(seconds)    print("os.sleep simulation for " .. seconds .. " seconds") end shutdown_regular(arg[1], arg[2]) --]]
Shutdown remote PC - by George - 12.07.2015, 15:30
