Resident script pump circulation
#27
You are trying to log value 'ValveStatesEstate' but you hasn't defined stagione so stagione equals nil so else condition is executed.
But generally when you extend this script maybe better would be create some function and do script more elastic also for the futureWink
See below (but still you must define stagione!):
valveStatesTagEstate = 'pompa_circolazione_giorno_estate' valveStatesTagInverno = 'pompa_circolazione_giorno_inverno' pumpGA = '2/0/1' openingValveTime = 60 -- time for fully open the valve (maximum time for next calculation) minInterval = 30 -- minimum offset for next calculation opened, firstTimestamp = false, 0 function getParamsFromValveStates(valvesTag)     local valveStates = grp.tag(valveStatesTag)     for v = 1, #valveStates, 1 do       valveState = valveStates[v]       if valveState.value then         opened = true         if firstTimestamp > 0 then             if firstTimestamp > valveState.updatetime then firstTimestamp = valveState.updatetime end         else             firstTimestamp = valveState.updatetime         end       end     end return opened, firstTimestamp end if not stagione then opened, firstTimestamp = getParamsFromValveStates(valveStatesTagEstate) else opened, firstTimestamp = getParamsFromValveStates(valveStatesTagInverno) end if opened then    fullyOpened = (os.microtime() - firstTimestamp) >= openingValveTime    if fullyOpened then        grp.checkwrite(pumpGA, true)        nextCalculationAfter = minInterval    else        grp.checkwrite(pumpGA, false)        nextCalculationAfter = openingValveTime + 1 - (os.microtime() - firstTimestamp) -- run a little after possible change    end else    grp.checkwrite(pumpGA, false)    nextCalculationAfter = openingValveTime + 1 end -- log('Next calculation after: ' .. nextCalculationAfter .. 's.') os.sleep(nextCalculationAfter)
Done is better than perfect
RE: Resident script pump circulation - by buuuudzik - 24.04.2018, 17:03
