test if resident script running
mintimer = 1 -- minimum timer value in seconds maxtimer = 60 -- maximum timer value in seconds objects = {  {    output = '3/6/1',    timer = '3/6/101',  },  {    output = '3/6/2',    timer = '3/6/102',  },  {    output = '3/6/3',    timer = '3/6/103',  },  {    output = '3/6/4',    timer = '3/6/104',  },  {    output = '3/6/5',    timer = '3/6/105',  },  {    output = '3/6/6',    timer = '3/6/106',  },  {    output = '3/6/7',    timer = '3/6/107',  },  {    output = '3/6/8',    timer = '3/6/108',  } } function dosleep(obj)  local timer = grp.getvalue(obj)  timer = tonumber(timer)  if timer then    if timer < mintimer then      timer = mintimer    elseif timer > maxtimer then      timer = maxtimer    end    sleep(timer) -- conversione da secondi a minuti  end end for _, item in ipairs(objects) do  grp.write(item.output, true)  dosleep(item.timer)  grp.write(item.output, false) end
Let me show you. This above is a event scheduler which run when group 3/6/201 is triggered (true or false it does not matter)
If script status group is 32/1/3 do you mean insert this below in the same script above?
status = script.status('scriptname')
value = status
grp.write(32/1/3, value)
I did that. I use this instruction at the beginning of the script and at the end. Problem is that I never received false to group 32/1/3.
I hope you understand what you mean.
RE: test if resident script running - by Domoticatorino - 26.04.2018, 11:52
