detect double, single and long press from wall switch
Yes, you are right. Still, you should check the event value in order not run the script when counter is 0, like this:
value = tonumber(event.datahex, 16) if value > 0 then   light1 = '1/2/1'   light2 = '1/2/2'   switcher_adress = '1/1/1'   os.sleep(1)   value = event.getvalue()   if value == 1 then     -- log('single press '.. switcher_adress)     grp.write(light1, not(grp.getvalue(light1)))   elseif value == 2 then     -- log('double ' .. switcher_adress)     grp.write(light2, not(grp.getvalue(light2)))   end   -- reset counter   if value > 0 then     grp.update(event.dst, 0)   end end
RE: detect double, single and long press from wall switch - by admin - 13.07.2015, 07:54
