Modbus TCP slave example
Due to 2-byte <> 4-byte conversion, you need to use two uint16 objects: 2/1/2 and 2/1/3 in this example. Float16 object address is 2/1/1.
1. Add a script to float16 object, it will split the value and write it to 2/1/2 and 2/1/3. Change 15.15.255 to your LM physical address so this script is only triggered from KNX bus but not from LM internally.
if event.src ~= '15.15.255' and event.src ~= 'local' then value = event.getvalue() raw = knxdatatype.encode(value, dt.float32).dataraw r1 = raw:byte(1) * 0x100 + raw:byte(2) r2 = raw:byte(3) * 0x100 + raw:byte(4) grp.update('2/1/2', r1, dt.uint16) grp.update('2/1/3', r2, dt.uint16) end
2. Attach a script to 2/1/3 (second uint16 object). It converts two uint16 regs to float32 internally and then writes the value to float16 object.
require('luamodbus') r1 = grp.getvalue('2/1/2') r2 = grp.getvalue('2/1/3') value = luamodbus.convert('float32', r1, r2) grp.write('2/1/1', value, dt.float16)
Modbus TCP slave example - by admin - 08.01.2016, 08:46
RE: Modbus TCP slave example - by Deniss - 15.01.2016, 08:58
RE: Modbus TCP slave example - by admin - 15.01.2016, 14:39
RE: Modbus TCP slave example - by admin - 18.01.2016, 12:57
RE: Modbus TCP slave example - by automatikas - 02.02.2017, 11:30
RE: Modbus TCP slave example - by admin - 02.02.2017, 12:09
RE: Modbus TCP slave example - by automatikas - 02.02.2017, 13:35
RE: Modbus TCP slave example - by automatikas - 29.03.2017, 10:26
RE: Modbus TCP slave example - by admin - 29.03.2017, 10:37
RE: Modbus TCP slave example - by leondias - 29.03.2017, 10:40
RE: Modbus TCP slave example - by automatikas - 29.03.2017, 10:41
RE: Modbus TCP slave example - by admin - 29.03.2017, 10:55
RE: Modbus TCP slave example - by automatikas - 29.03.2017, 11:15
RE: Modbus TCP slave example - by Deniss - 20.04.2017, 06:47
RE: Modbus TCP slave example - by admin - 20.04.2017, 15:38
RE: Modbus TCP slave example - by duvelken - 02.12.2017, 08:13
RE: Modbus TCP slave example - by admin - 03.12.2017, 09:58
RE: Modbus TCP slave example - by FatMax - 13.12.2018, 14:44
RE: Modbus TCP slave example - by admin - 13.12.2018, 15:23
RE: Modbus TCP slave example - by FatMax - 13.12.2018, 15:53
RE: Modbus TCP slave example - by rw_echo - 16.03.2023, 07:57
RE: Modbus TCP slave example - by admin - 17.03.2023, 10:52
