Art-Net DMX
Resident script, sleep time = 0. Might require some change to work with C-BUS objects.
if not client then   ip = '192.168.2.43'   mapping = { '1/1/1', '1/1/2', '1/1/3', '2/1/1', '2/1/2', '2/1/3' }   universe = 1   physical = 0   udpsock = require('socket').udp()   addrtoid = {}   values = {}   for id, addr in ipairs(mapping) do     obj = grp.find(addr)     addrtoid[ addr ] = id     if obj then       value = obj.value or 0       if obj.datatype == dt.scale then         value = math.floor(value * 2.55)       end     else       value = 0     end     values[ id ] = value   end   function send()     local cmd = string.char(       -- null byte; ARTNET_DMX opcope; protocol version 14, sequence not defined       0, 0, 0x50, 0, 14, 0,       -- physical input port from which DMX512 data was input       bit.band(physical, 0xFF),       -- 15 bit Port-Address (universe)       bit.band(universe, 0xFF), bit.rshift(universe, 8),       -- Length       bit.rshift(#values, 8), bit.band(#values, 0xFF)     )     local req = 'Art-Net' .. cmd .. string.char(unpack(values))     udpsock:sendto(req, ip, 0x1936)   end   function eventhandler(event)     local id = addrtoid[ event.dst ]     if id then       values[ id ] = busdatatype.decode(event.datahex, dt.uint8, event.dstraw)       send()     end   end   client = require('localbus').new()   client:sethandler('groupwrite', eventhandler)   send() end client:step()
Art-Net DMX - by sjfp - 11.05.2018, 12:33
RE: Art-Net DMX - by edgars - 11.05.2018, 13:08
RE: Art-Net DMX - by sjfp - 11.05.2018, 13:20
RE: Art-Net DMX - by admin - 14.05.2018, 06:28
RE: Art-Net DMX - by Erwin van der Zwart - 14.05.2018, 07:53
RE: Art-Net DMX - by sjfp - 14.05.2018, 10:26
RE: Art-Net DMX - by admin - 14.05.2018, 11:02
RE: Art-Net DMX - by Erwin van der Zwart - 14.05.2018, 19:56
RE: Art-Net DMX - by sjfp - 21.05.2018, 17:16
RE: Art-Net DMX - by admin - 15.05.2018, 06:52
RE: Art-Net DMX - by admin - 22.05.2018, 06:00
RE: Art-Net DMX - by sjfp - 22.05.2018, 17:19
RE: Art-Net DMX - by admin - 23.05.2018, 08:35
RE: Art-Net DMX - by sjfp - 23.05.2018, 09:49
RE: Art-Net DMX - by lcrowhurst - 03.02.2020, 03:20
RE: Art-Net DMX - by admin - 03.02.2020, 11:41
RE: Art-Net DMX - by lcrowhurst - 03.02.2020, 12:15
RE: Art-Net DMX - by admin - 03.02.2020, 12:51
RE: Art-Net DMX - by lcrowhurst - 04.02.2020, 12:56
RE: Art-Net DMX - by tomnord - 07.05.2024, 12:54
RE: Art-Net DMX - by admin - 04.02.2020, 13:09
RE: Art-Net DMX - by lcrowhurst - 06.02.2020, 01:21
RE: Art-Net DMX - by lcrowhurst - 07.09.2020, 22:49
RE: Art-Net DMX - by admin - 07.05.2024, 13:07
RE: Art-Net DMX - by tomnord - 07.05.2024, 13:17
RE: Art-Net DMX - by admin - 07.05.2024, 13:20
RE: Art-Net DMX - by tomnord - 07.05.2024, 13:21
RE: Art-Net DMX - by admin - 07.05.2024, 13:42
RE: Art-Net DMX - by phongvucba - 02.04.2026, 03:06
