Color spectrum dimming
Hello everybody!
I was wondering if it is possible to make this kind of "effect" with a simple RGB strip. When holding a simple push button set to dimming, colors of the strip would go across the spectrum of all colors (with speed / step size as I choose), when released it would stay at that color. Second button would do the same but backwards. Not sure if this would be any effective but it's the only way I thought of to make this using a physical push button. I have 3 unsigned integer group adresses (R,G,B). I tried to do it with this script I lightly modified but it doesn't work well. The script is in two event scripts, both 3 byte dimming from a pushbutton, one is set to brighter (ON) and the second one to darker (OFF).
step = 1 stepTime = 0.001 ballastAddress1 = 19 --RED ballastAddress2 = 27 --GREEN ballastAddress3 = 28 --BLUE gatewayID='internal' ----------------------------------------------------------------------------------------------------- valuein = event.getvalue() require('user.dali')    res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress1 })    res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress2 })    res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress3 })  -- read ok        if res then      status = res:byte()        end while( valuein==9 ) do  status = status + step     if (status >254) then              dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = 254})              dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = 254})              dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = 254})          else      dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = status})      dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = status})      dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = status})     end  valuein = grp.getvalue(event.dst)  os.sleep(stepTime) end     while( valuein==1 ) do  status = status - step      if (status <0) then          dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = 0})          dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = 0})          dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = 0})          else        dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = status})        dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = status})        dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = status})      end    valuein = grp.getvalue(event.dst)  os.sleep(stepTime) end
Color spectrum dimming - by Jayce - 23.05.2018, 13:40
RE: Color spectrum dimming - by Daniel - 23.05.2018, 15:10
