KNX physical address check
I need to check if the devices on my line are alive. I am using LM Load Balnce that doesn't have TP1 on board knxlib.ping won't work.
Can someone suggest another way on how to implement same functionality without the use of knxlib.ping?
Thank you in advance
KNX physical address check - by Peter - 13.10.2015, 11:33
RE: KNX physical address check - by admin - 13.10.2015, 11:53
RE: KNX physical address check - by Peter - 13.10.2015, 12:10
RE: KNX physical address check - by Peter - 15.10.2015, 06:07
RE: KNX physical address check - by gtsamis - 21.01.2016, 23:30
RE: KNX physical address check - by Ruslan - 28.02.2016, 12:45
RE: KNX physical address check - by rocfusion - 28.02.2016, 20:47
RE: KNX physical address check - by Ruslan - 29.02.2016, 05:44
RE: KNX physical address check - by rocfusion - 29.02.2016, 05:54
RE: KNX physical address check - by admin - 02.03.2016, 08:46
RE: KNX physical address check - by Bergman - 04.11.2025, 20:30
RE: KNX physical address check - by admin - 05.11.2025, 08:06
RE: KNX physical address check - by os.sleep - 13.11.2025, 05:56
RE: KNX physical address check - by Bergman - 06.11.2025, 18:48
RE: KNX physical address check - by Daniel - 13.11.2025, 08:49
RE: KNX physical address check - by os.sleep - 13.11.2025, 14:29
