12.06.2018, 19:46
(11.06.2018, 21:59)Erwin van der Zwart Wrote: Hi,
Try this:
For enable/disable script above from 1 bit use this: (sample is assuming event script script above is called 'timebasedevent')Code:now = os.date('*t') if now.hour >= 8 and now.hour < 13 then grp.write('1/1/1', true) elseif now.hour >= 13 and now.hour < 14 then grp.write('1/1/1', false) end
BR,Code:if event.getvalue() == true then script.enable('timebasedevent') else script.disable('timebasedevent') end
Thank you .
