NodOn wallplug - multiple event triggering on one trigger
(12.07.2018, 10:16)admin Wrote: Are you talking about standard EnOcean wall switch, single or double rockers?
This one:
https://www.amazon.de/Nod-SIN-2-1-01-Eno...KAQMJ15DWH
One relay and 2 inputs, but I've connected only first input. It is a device which has profile not supported by LM but by using some other it works:
F6-04-01 as EnOcean->KNX
F6-01-03 as KNX->EnOcean
I've tried filter one value but unfortunately probably this 2 telegrams starts on the same time and filter telegram is inverted on same value:
value = event.getvalue() alias = grp.alias(event.dst) zone, mode = alias:match('(.*)_(.*)') log(mode, value, event) statusAlias = zone .. '_status' status = grp.getvalue(statusAlias) filterAlias = zone .. '_filter' filter = grp.getvalue(filterAlias) if mode == 'toggle' and not value then  if filter then    grp.write(statusAlias, not status)  end  grp.write(filterAlias, not filter) elseif mode == 'on/off' then  grp.write(statusAlias, value) end
Done is better than perfect
RE: NodOn wallplug - multiple event triggering on one trigger - by buuuudzik - 12.07.2018, 10:27
