12.07.2018, 11:55
Thanks for correction
I named this inputs as "toggle" because they send 0 and 1 but this is not a relay or input state so the value can be ommited. These are my first steps with EnOcean and I see that when LM has antenna it can reach through the walls (at this moment through concrete 2 walls and 7m and module was inside the plastic box, with WiFI in the air).
I remember that when I've used ZWAVE modules from fibaro(which I've appreciate for their functionality and look) the communication without any walls was very, very low and people which stands between module and the controller decrease the range significantly(most times totally). For me EnOcean is more stable and faster.
I named this inputs as "toggle" because they send 0 and 1 but this is not a relay or input state so the value can be ommited. These are my first steps with EnOcean and I see that when LM has antenna it can reach through the walls (at this moment through concrete 2 walls and 7m and module was inside the plastic box, with WiFI in the air).I remember that when I've used ZWAVE modules from fibaro(which I've appreciate for their functionality and look) the communication without any walls was very, very low and people which stands between module and the controller decrease the range significantly(most times totally). For me EnOcean is more stable and faster.
Done is better than perfect
