Sony Simple IP Protocol
require('socket') -- bravia IP ip = '192.168.1.23' -- IR power off command, must be 24 chars long cmd = '*SCIRCC0000000000000000\n' -- power-on -- cmd = '*SCPOWR0000000000000001\n' sock = socket.tcp() sock:settimeout(3) res, err = sock:connect(ip, 20060) if res then  res, err = sock:send(cmd)  if res then    alert('send OK')  else    alert('send failed: ' .. tostring(err))  end else  alert('connect failed: ' .. tostring(err)) end sock:close()
This Code had an error regarding my Bravia, to turn off.
do not work at all, i had to replace IRCC with POWR
cmd = '*SCPOWR0000000000000000\n'
That did make it work!
Sony Simple IP Protocol - by josep - 24.02.2016, 09:23
RE: Sony Simple IP Protocol - by admin - 24.02.2016, 11:45
RE: Sony Simple IP Protocol - by DarthPaul - 13.07.2018, 07:04
RE: Sony Simple IP Protocol - by josep - 24.02.2016, 14:39
RE: Sony Simple IP Protocol - by admin - 25.02.2016, 09:37
RE: Sony Simple IP Protocol - by josep - 25.02.2016, 19:53
RE: Sony Simple IP Protocol - by phongvucba - 22.05.2017, 15:46
RE: Sony Simple IP Protocol - by buuuudzik - 08.06.2017, 16:24
RE: Sony Simple IP Protocol - by phongvucba - 14.07.2017, 10:51
