28.08.2018, 20:23
(This post was last modified: 28.08.2018, 20:55 by XSPA2474KW.)
(28.08.2018, 19:06)Erwin van der Zwart Wrote: Hi,
Can you check under NAT if the service is enabled (both current NAT and current hardware NAT status)
- Enable NAT Control - If enabled, the NAT function and the Forwarding configuration will take effect.
- Disable NAT Control - If disabled,neither NAT function nor Forwarding configuration will take effect.
Hi Erwin
the problem remains
Also, all the other ports work well.
I have more 14 ports and all are ok.
