Connection and Coonfiguration
#43
Well the fact that you can connect locally means there is nothing wrong with the controller and all settings are good in the device.
The only reason why it does not work can only be in your router settings.
I would try with UDP only and try with restarted router to see if it starts forwarding your connection.
Connection and Coonfiguration - by XSPA2474KW - 29.07.2018, 10:47
RE: Connection and Coonfiguration - by AEK - 30.07.2018, 08:08
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 07:49
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 08:23
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 09:07
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 09:29
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 09:39
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 09:59
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 11:43
RE: Connection and Coonfiguration - by Daniel - 03.08.2018, 13:15
RE: Connection and Coonfiguration - by Daniel - 24.08.2018, 07:37
RE: Connection and Coonfiguration - by Daniel - 24.08.2018, 08:28
RE: Connection and Coonfiguration - by Daniel - 27.08.2018, 11:37
RE: Connection and Coonfiguration - by admin - 28.08.2018, 18:15
RE: Connection and Coonfiguration - by Erwin van der Zwart - 28.08.2018, 21:01
RE: Connection and Coonfiguration - by Daniel - 29.08.2018, 11:43
RE: Connection and Coonfiguration - by edgars - 29.08.2018, 12:01
RE: Connection and Coonfiguration - by edgars - 29.08.2018, 13:49
RE: Connection and Coonfiguration - by edgars - 30.08.2018, 08:57
RE: Connection and Coonfiguration - by edgars - 30.08.2018, 13:49
RE: Connection and Coonfiguration - by Daniel - 30.08.2018, 18:37
