Check SD card errors
(24.09.2018, 07:34)Daniel. Wrote: Hi
New LMs use NOR flash, industrial quality.  Whole database, storage and trends are stored on to this flash. SD cards is now used only to store static files which are written once. SD  was failing due to bigger amount of data was written now we hardly ever use it.  Even when it will switch to read only LM will keep running as normal and everything will work just fine.
As we want to preserve the card as much as possible any script which will be checking it state will just make unnecessary additional write to it.
I don't think there is any need for such script now.
If I understand correctly, buuuudzik's script does not write or read from the SD card, so it should be OK to run it every now and then?
Check SD card errors - by buuuudzik - 23.02.2018, 21:21
RE: Check SD card errors - by baggins - 21.09.2018, 21:30
RE: Check SD card errors - by buuuudzik - 21.09.2018, 21:51
RE: Check SD card errors - by Daniel - 24.09.2018, 07:34
RE: Check SD card errors - by baggins - 24.09.2018, 11:28
RE: Check SD card errors - by buuuudzik - 24.09.2018, 07:50
RE: Check SD card errors - by Daniel - 24.09.2018, 08:15
RE: Check SD card errors - by buuuudzik - 24.09.2018, 08:29
RE: Check SD card errors - by Daniel - 24.09.2018, 08:32
RE: Check SD card errors - by buuuudzik - 24.09.2018, 11:49
RE: Check SD card errors - by FatMax - 28.10.2018, 15:07
RE: Check SD card errors - by buuuudzik - 28.10.2018, 15:22
RE: Check SD card errors - by FatMax - 28.10.2018, 15:24
RE: Check SD card errors - by admin - 29.10.2018, 07:01
RE: Check SD card errors - by buuuudzik - 29.10.2018, 07:14
