Threads: 89
(24.12.2020, 08:46)admin Wrote: This should do what you want. You can change the interval (it is 2000 milliseconds now) if needed.
Code: var interval;
// Function to play audio by URL
function Play_Audio(url){
//console.log(OS_Version)
if (OS_Version === 'Android' || OS_Version === 'U.Motion' ){
//alert(OS_Version);
snd.src = url;
snd.pause();
sndcurrentTime = 0;
//snd.load();
snd.play();
} else {
request.open("GET", url, true);
request.responseType = "arraybuffer";
request.onload = function(){
ctx.decodeAudioData(request.response, onDecoded);
function onDecoded(buffer){
var bufferSource = ctx.createBufferSource();
bufferSource.buffer = buffer;
bufferSource.connect(ctx.destination);
bufferSource.start();
request.send();
// Function to create event listeners
function CreateListeners(groupaddr,url){
// Make event listener to object
grp.listen(groupaddr, function(object, state) {
var value = object.value;
var enabled = grp.getvalue('32/2/1');
clearInterval(interval);
if (state == 'value' && value == 1 && enabled) {
Play_Audio(url);
interval = setInterval(function() {
Play_Audio(url);
}, 2000);
}, true);
// Start creating listeners
for (var i in AudioTable) {
CreateListeners(AudioTable[i].address,AudioTable[i].url);
Great! Thank you so much. And best wishes!
Peppe
Threads: 89
(21.12.2020, 07:32)admin Wrote: You can use grp.taglisten(tag_name, callback_function, all_events) instead of grp.listen(group_address, callback_function, all_events) for this
I tried to use grp.taglisten instead of grp.listen... but evidently I made some mistake:
Code: // allarme sonoro
// Closing current script section to add elements
</script>
<audio id="SE_Audio" style="display: none;"></audio>
<script type="text/javascript"> // Starting new script section after adding elements
$(function(){
// Table with parameters
var AudioTable = [
{ tag_name:"beep", url:"/scada/resources/img/beep.mp3"},
// { address:"32/2/1", url:"/user/audio2.mp3" },
//{ address:"32/2/2", url:"/user/audio3.mp3" },
var ctx = new(window.AudioContext || window.webkitAudioContext || window.mozAudioContext || window.oAudioContext || window.msAudioContext), request = new XMLHttpRequest();
var snd = document.getElementById("SE_Audio");
function getMobileOperatingSystem() {
var userAgent = navigator.userAgent || navigator.vendor || window.opera;
//console.log(userAgent)
if (userAgent.match(/iPad/i) || userAgent.match(/iPhone/i) || userAgent.match(/iPod/i)) {
return 'iOS';
} else if ( userAgent.match(/Android/i)) {
return 'Android';
} else if ( userAgent.match(/iKonWebTouch/i)) {
return 'U.Motion';
} else {
return 'PC';
var OS_Version = getMobileOperatingSystem();
// Fix iOS Audio Context
(function() {
var fixAudioContext = function (e) {
if (ctx) {
// Create empty buffer
var buffer = ctx.createBuffer(1, 1, 22050);
var source = ctx.createBufferSource();
source.buffer = buffer;
// Connect to output
source.connect(ctx.destination);
// Play sound
if (source.start) {
source.start(0);
} else if (source.play) {
source.play(0);
} else if (source.noteOn) {
source.noteOn(0);
// Check if document is loaded in iframe
if (window.frameElement){
// Remove event listeners from parent
var thisparent = window.parent;
thisparent.document.removeEventListener('touchstart', fixAudioContext);
thisparent.document.removeEventListener('touchend', fixAudioContext);
// Remove events
// Add event listeners to parent
// Event listener for iOS 6-8 (was previous touchstart event)
thisparent.document.addEventListener('touchstart', fixAudioContext);
// Event listener for iOS 9+ (is now touchend event)
thisparent.document.addEventListener('touchend', fixAudioContext);
var interval;
snd.src = url;
snd.pause();
sndcurrentTime = 0;
//snd.load();
snd.play();
} else {
request.send();
function CreateListeners(tag_name,url){
grp.taglisten(tag_name, function(object, state) {
var enabled = grp.getvalue('32/1/21');
Play_Audio(url);
Play_Audio(url);
}, 2000);
}, true);
CreateListeners(AudioTable[i].tag_name,AudioTable[i].url);
Best Wishes
Peppe
Threads: 8
This should work:
Code: // Closing current script section to add elements
</script>
$(function(){
return 'iOS';
return 'Android';
return 'U.Motion';
} else {
return 'PC';
(function() {
if (ctx) {
// Play sound
if (source.start) {
source.start(0);
source.play(0);
source.noteOn(0);
// Remove events
var interval;
//console.log('play activated')
snd.src = url;
snd.pause();
sndcurrentTime = 0;
snd.play();
} else {
request.send();
grp.taglisten("beep", function(object, state) {
// Enable for testing
//enabled = true;
Play_Audio("/scada/resources/img/beep.mp3");
}, 2000);
}, true);
Threads: 89
(27.12.2020, 12:14)Erwin van der Zwart Wrote: This should work:
</script>
$(function(){
return 'iOS';
return 'Android';
return 'U.Motion';
} else {
return 'PC';
(function() {
if (ctx) {
// Play sound
if (source.start) {
source.start(0);
source.play(0);
source.noteOn(0);
// Remove events
var interval;
snd.src = url;
snd.pause();
sndcurrentTime = 0;
snd.play();
} else {
request.send();
//enabled = true;
}, 2000);
}, true);
Ok, sorry... I re-tested it.. now it's working fine!
Thank you so much!
Peppe
Threads: 3
HI:
I'm trying to use this function but no sound is reproduced.
If I try to execute the file in the explorer edge iI see only text not sound. The same file in my PC I do.
"ID3#TSSELavf58.76.100ÿó`Ĉ±ðIH2ᶈ ‚‚dé…A!pL7!@¡0@11Z=Q;t£º08àAØÒïƒáöâppŸXñþƒù@AØ!ð@p 8>} ‡L‡åÃõƒà̸>ƒàø …*h¤*„D†1l‹¢Ööa!qòždX#åFäk „ÿóbÄ 'ZÎ_h;TÀ(:wƒO‚BH Ðd*A¸C£,¦É›‚-`¬†!#ôÏ¢K’ã€Ol@„Ü SDÜú&é‰QØ–$L‡2TÊY7CðRÖ0¥æ šÍWÿÿ/šh¤Èº¹‚Ó¹’*uÿÿöDù¢‚Ïê. 4Oÿÿôâ•Ä€$“»×" "“‚ÿób..... it is like this
What is the reason?
thanks in advance.
