problem with 4g modem
#21
Post what you have in System config > Status > System log.
Thank for the quick reply.
Here it goes.
What LM hardware model are you using?
LM5p2-RIO3LTE
LM5M3CV15xA23010267
Do you have 3G/4G connection enabled? If it's disabled then the on-board modem won't be initialized.
It was disabled. When we try to enable it the LM stops responding.
This most likely caused by LM using mobile connection gateway instead of Ethernet.
Follow this guide if you only need SMS without 3G/4G: https://forum.logicmachine.net/showthrea...7#pid33127
It worked. Thanks!
I still have a strange situation. In the alert I still get "SMS handler lost connection" but the SMS are getting through. I only happens with a card from one provider. Using a card from a different provider it doesn't happen.
Modify AT:run() function in the user library as follows and post what you get in LM Logs tab.
function AT:run()
  local res, err, cmd, pos, sms
  res, err = self:read()
  if err then
    if err ~= 'timeout' then
      log('run error', err)
    return err == 'timeout'
  -- check for incoming command
  if res:sub(1, 1) ~= '+' then
    return true
  pos = res:find(':', 1, true)
  if not pos then
    return true
  -- get command type
  cmd = res:sub(2, pos - 1)
  -- check only for incoming sms
  if cmd ~= 'CMTI' then
    log('run cmd', cmd)
    return
  -- read from sim
  sms = self:incsms(res)
  -- sms seems to be valid, pass to handler if specified
  if sms and self.smshandler then
    self.smshandler(sms)
  return true
Here goes the log.
Change the same function as follows and see if it helps.
function AT:run()
  if err then
    return true
  if not pos then
    return true
  -- get command type
  if cmd == 'CMTI' then
    -- read from sim
  return true
