03.07.2020, 06:47
If you want to use API why not use Telegram instead? It's free and easy to configure. See this: https://forum.logicmachine.net/showthrea...1#pid17111
How to control the KNX bus via SMS and send notices via SMS?
03.07.2020, 06:47
05.01.2023, 06:06
with the instruction and files in post 3 I am now able to receive and send sms. THX! I also managed to reboot via SMS and get back some information (e.g. IP) when sending a sms with "status" as content to LM. I now want to get back the signal status of the modem via sms. ASFAIK the AT-Command "AT+CSQ" delivers this information but unfortunately I have no clue how to implement this (my lua and AT-Command skills are not the best ![]() Can anyone help? Thx in advance!
05.01.2023, 13:16
1. Modify the user library send function so it returns the command reply/result:
Code: -- send command to terminal 2. Add before handler = function(sms) in the resident script: Code: readcsq = function() 3. Add before udphandler(server) in the resident script: Code: now = os.time() This will read the signal quality every 15 seconds and will set global variable quality that you can use in the SMS reply message.
06.01.2023, 11:58
Works perfect - THX!
09.01.2023, 10:56
Is it possible to change APN via SMS and reconnect to the new APN? I am sure it is but my skills ...
I need this to connect to my LM in case the VPN is down. Normally I use the APN "internet.telekom, tm ,tm" and do not want to change this default setting (bacause of security reasons) - with this APN you get a private WAN-IP like 10.x.x.x and AFAIK you can not connect to private IPs. With the APN "internet.t-d1.de, internet, t-d1" you get a non private IP like 32.x.x.x and you can connect to it. Another point: In the resident script the PIN code needs to be set - either as a number or a object-variable. Is it also possible to get the PIN code out of the system preferences where it usually also has to be set? THX in advance! |
« Next Oldest | Next Newest »
