Modify a small sms script
Hi.
I use this small script on a 1bit group address:
require('user.sms')
sendsms('12345678', 'test sms')
I then get a text message every time the group address value changes between 1 and 0.
What do i have to change in this script to only get a sms when the value is either 1 or 0?
if value = 0, then:
require('user.sms')
Kai-Roger
Value can be either true or false for booleans. You can write it like this:
if event.getvalue() == false then
Then i will write it like this:
require('user.sms')
Do i need to have a closure to the script in Lua, or is this not a normal practice? like:
if not then: exit
Okay. I just found out how it works. I need an "end" at the end Smile
require('user.sms')
When i run the script, i get a popup on my ipad with Visu.
It says
http://192.168.1.99
sending sms: 12345678 test sms
And i then have to press a OK button.
How to remove this message on visu?
There must be a alert() somewhere, probably in the user lib that you need to disable/remove.
Another option is to disable the popup in the vis config settings but then the alerts are still added to the alert tab.
Thanks. Now i understand why this shows up on the Visu.
I could not find it in the script for deactivation. This is a script by admin 28.08.2015 09:20 in the below link.
https://forum.logicmachine.net/showthrea...hlight=sms
Maybe someone can point me in the right direction?  Smile
Its in the resident script..
Add — before the line to disable the alert.
alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))
Hi.
That did not work, but thanks for pointing me in the right direction. I added -- in front of the first line of the following, and it works great  :)
    --alert('sending sms: ' .. msg)
    modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))
