26.10.2018, 12:53
What is the best way for synchronize projects over a few LMs?
I see that Import neighbours works sometimes but not in all cases e.g. I have LM LB and LM3 V2 and I cannot import objects between them (import objects from LM LB to LM3, 'Remote services' are on and the error is 401), or probably to use this function for all objects I must mark all of them as 'Export'. And also when there is a conflict not all objects will be imported.
I think Export should be added to interface same as Import, maybe with some conditions like what to do when there is some conflict.
Done is better than perfect
