01.11.2018, 19:42
Hi, I try to connect to Schneider-electric Homelynx and get the airflow from an IVP AHU ventilation unit with a climactix controller.
I need to compare two values in order to control a mixing valve.
The valve opens and closes until the two values are as equal as possible.
The value is to be retrieved from a Holding register with the address 4x0055 and 4x0056.
But unfortunately I do not get any values, it seems that it does not connect or I have typed the wrong code to get the air value correctly.
I would be very grateful if you can help me with this problem
/Tommy
require('luamodbus')
if not mb then
mb = luamodbus.tcp()
mb:open('192.168.201.53')
mb:connect()
mb:setdebug(true)
openvalue = grp.getvalue('6/3/1')
tfvalue = mb:readinputregisters(54)
ffvalue = mb:readinputregisters(55)
mb:close()
if tfvalue > ffvalue then
if openvalue < 220 then
openvalue = openvalue + 25
if ffvalue < ffvalue then
if openvalue > 25 then
openvalue = openvalue - 25
grp.write('6/3/1', openvalue)
/Tommy
