Scheduled time parameters
Hi.
Where and what should i write in the attatched picture to make the script run every 1 hour all the time?
I sort of made it run every whole and half hour by writing this:
Minute: */30
Hour: *
Day of month: *
Just put 1 in a minute and rest * then script will run every hour when minute 1 happen.
(02.11.2018, 10:56)Daniel. Wrote: Just put 1 in a minute and rest * then script will run every hour when minute 1 happen.
So if i put in like this, then it will run every 2 hours?:
Minute: 1
Hour: */2
Day of month: *
If you want every second hour then you can just put * in minute too and for hour as you did. But yes it will run every second hour on the first minute of an hour.
(02.11.2018, 11:18)Daniel. Wrote: If you want every second hour then you can just put * in minute too and for hour as you did. But yes it will run every second hour on the first minute of an hour.
Thanks Smile
