Cancel Telegram
Hello
I would need to cancel a telegram that was transmitted on the bus if a virtual address had a value of 1.
Example:
if the group address
1/1/1 Virtual Control = 1
that will cancel all the telegrams of the address:
2/1/1 Door opening = 1
so that the door does not open, I would also like to be able to cancel a telegram for hours, that is to say from 22:00 to 07:00 the address
it does not execute the opening when it is transmitted on the bus.
Thanks for helping, greetings
You can’t cancel telegrams, but what you can do is create a logic gate, if the virtual object is true then input -> output.
In script it would like this:
if grp.getvalue(‘32/1/1’) == true then
grp.write(‘1/1/2’, event.getvalue())
Put this as event on your input object, 1/1/2 is the output.
