10.11.2018, 14:09
could you give some info about this method? I have a few LMs on installation and now I am developing some bus traffic monitoring in different lines.
I've tried used above method but I've received such result:
This is from LM4 which is in IP line, and iptx is still the same but there is a lot of traffic in line in two directions on IP side because there is no TP connected. So it should be variable and both iptx and iprx should be more than 0.
* table:
[iptx]
* number: 1263
[repeats]
* number: 0
[iprx]
* number: 0
[tprx]
* number: 0
[tptx]
* number: 0This is from LM4 which is in IP line, and iptx is still the same but there is a lot of traffic in line in two directions on IP side because there is no TP connected. So it should be variable and both iptx and iprx should be more than 0.
Done is better than perfect
