Script not working properly
Hello everyone,
In the past we used to make our light group feedbacks via event scripts tagged to specific group, but recently I found this script, which makes this job a bit easier:
if not client then
 -- each group has 3 fields:
 -- tag - status object tag
 -- output - status output object
 -- mode - calculate mode (and/or/avg)
 groups = {
 -- time to wait between last telegram from any status in group and update
 updatedelay = 1
 -- object value cache
 values = {}
 -- object datatype cache
 datatypes = {}
 -- send update only when value changes
 grp.checkupdate = function(alias, value)
   if values[ alias ] ~= value then
     grp.write(alias, value)
 calc = {}
 -- AVERAGE value
 calc['avg'] = function(group)
   local result, count, value = 0, 0
   for _, address in ipairs(group.objects) do
     value = values[ address ]
     -- number must be in [0..100] range
     if type(value) == 'number' then
       result = result + value
       count = count + 1
     -- boolean true is 100%, false is 0%
     elseif type(value) == 'boolean' then
       if toboolean(value) then
         result = result + 100
       count = count + 1
   if count > 0 then
     result = math.floor(result / count + 0.5)
     grp.checkupdate(group.output, result)
 -- AND gate
 calc['and'] = function(group)
   local result = true
     result = result and toboolean(values[ address ])
 -- OR gate
 calc['or'] = function(group)
   local result = false
     result = result or toboolean(values[ address ])
 -- prepare each group
 for _, group in ipairs(groups) do
   object = grp.find(group.output)
   -- cache output status object value and datatype
   values[ object.address ] = object.data
   datatypes[ object.address ] = object.datatype
   group.output = object.address
   -- group input status object list
   group.objects = {}
   -- find all status objects and cache values and datatypes
   objects = grp.tag(group.tag)
     table.insert(group.objects, object.address)
   -- force update on first run
   group.timer = 0
   -- calc function reference
   group.fn = calc[ group.mode ]
 -- handle group writes
 function eventhandler(event)
   local dst, datatype
   dst = event.dst
   datatype = datatypes[ event.dst ]
   -- unknown object, stop
   if not datatype then
     return
   values[ dst ] = dpt.decode(event.datahex, datatype)
   -- check if any group needs to be updated
       if address == dst then
         group.timer = updatedelay
 client = eibdgm:new({ timeout = 0.25 })
 client:sethandler('groupwrite', eventhandler)
tsec, tusec = os.microtime()
client:step()
delta = os.udifftime(tsec, tusec)
-- check if any group has an active timer
 timer = group.timer
 if timer then
   timer = timer - delta
   -- timer expired, run calc function
   if timer <= 0 then
     group.fn(group)
     timer = nil
   group.timer = timer
Problem is, that this script works for awhile, but if many groups are starting to send feedbacks it kind of "crashes" because it stops sending feedbacks and to overcome this you have to disable/enable script to make it work again, why does this happen and is there a fix to it? I could of course use some kind of method to automatically disable/enable script once in awhile but I dont think this is a good practice and effective way of doing it. Maybe someone have ideas or had this problem before?
Thanks in advance.
Which firmware version are you running? How many groups do you have?
Version is 20170927. I have 18 groups in total which are working in "OR" mode and each group consist of atleast 3-4 different light addresses.
Try logging what grp.write returns:
res, err = grp.write(alias, value)
log(res, err)
It logs:
Quote:* arg: 1
 * nil
* arg: 2
 * string: cannot send nil value
Try upgrading firmware to 2018 RC1 and see if it helps.
